Will these fit?
19 Oct 2011
The motherboard will fit in the case and it already comes with a cheap PSU.
Buy a better quality PSU and a case with better cooling.
If you want an idea of what to get please list your full spec.
The motherboard does indeed fit the case, its ATX.
I wont comment on your choice of case as its a personal decision.
The PSU on the other hand is something I would advise you to avoid, get a named reputable make.
i know my choice of case is appauling, but im trying to cheapen things down a little without damaging spec :P, full list incomming
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £94.99
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £89.99
OCZ ZS Series 550W '80 Plus Bronze' Power Supply OCZ ZS Series 550W '80 Plus Bronze' Power Supply £54.98
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM
OcUK Galaxy III Tower Case - Black (450W PSU) OcUK Galaxy III Tower Case - Black (450W PSU) £34.99
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) £21.98
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £13.98
TP-Link 150Mbps High Gain Wireless-N USB Adapter (TL-WN722N) TP-Link 150Mbps High Gain Wireless-N USB Adapter (TL-WN722N) £9.98
The usb wireless is just for now, and my gfx card is going to be a seperate purchase, looking to tone down on the non-essentials
There are plenty of cases around £30 which will take 120mm fans for better and quieter cooling.
Something like this or this and get a cheap second 120mm fan.
The only fan that appears to come with the case you've picked is the 90mm one on the side door.
