Hi everybody,
It's been many years since I've had to choose hardware, so forgive my ignorance, as things have changed quite a bit!
I've come up with the following specs, but just wondering if any changes are recommended. Although the specs are probably more for gaming, my use will be more for things like PhotoShop and video editing.
Motherboard: Gigabyte Z170-Gaming K3 Intel Z170 DDR4 ATX
Processor: Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4 PC4-24000C 15 3000MHz Dual Channel (CMK 16GX4M2B30
CPU Cooler: Alpenfohn Brocken ECO CPU Cooler - 120mm
M.2 SSD for OS: Samsung SM951 128GB M.2 PCI-e Gen3 *Gbps x 4 AHCI SSD
Hard Drive: Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
Optical Drive: OcUK 24 x DVD+RW SATA ReWriter (Black) - OEM
Graphics card: MSI GeForce GTX 950 OC 2048MB GDDR5 PCI-Express
PSU: be quiet! Pure Power L8 600W '80 Plus Bronze' Power Suppy - With 120mm Silent Wing Fan Built in.
I already have a JeanTech Phong ATX Midi Tower case that I bought years ago, that's still in its box, so I'm hoping I can use that!
I'm wondering about the M.2 SSD Samsung SM951. From my initial research It seems like a bit of a kerfuffle getting the OS on. Disconnecting SATA cables, changing bios, installing OS via usb etc., Once that has been done, can programs be added to the C drive in the normal way via Optical drive or off of the hard drive?
I have some programs that have to run off the C drive, so if that is going to be an issue I'll have to rethink using the Samsung SM951 in favour of a SATA SSD.
I hope someone can advise?
Myles
Myles
