Will this air cooler be compatible ?
25 Jan 2006
Kent ,UK
Hello , after buying the Raijintek Pallas to cool my i5 4690k , if anybody knows Please if the GA-Z97N-Gaming 5 Motherboard fitted with Raijintek Pallas 140mm Low Profile CPU Cooler be compatible ,
i know the low memory sticks i have go under the heatsink ok, but will the cpu heatsink back plate be ok & not make contact with parts
https://www.overclockers.co.uk/raijintek-pallas-140mm-low-profile-cpu-cooler-hs-005-rt.html
http://uk.gigabyte.com/products/product-page.aspx?pid=4999#ov
case SST-SG05BB-Lite Sugo USB 3.0
https://www.overclockers.co.uk/silverstone-sst-sg05bb-lite-sugo-usb-3.0-black-ca-351-sv.html
Othewies i have to buy one & hope it fit ok ,if not return it to overclockers for not being compatible.
placed order , should be ok , Looks like the only one way to mount it to my itx board are with heatpipes to the rear /io shield .
love the cooler as its in first place of high end low profile coolers ,
http://www.frostytech.com/articleview.cfm?articleid=2765&page=6
Where sub-70mm heatsinks are considered exclusively, Raijintek's Pallas comes out on top, seconded by Zalman's CNPS8900 Extreme in both the AMD 125W and Intel LG115x/775 charts. There are no other sub-70mm tall heatsinks in the LGA2011 thermal test chart, so the Pallas wins the crown here... for the time being. Fan speed caveats aside, the Raijintek Pallas heatsink is well worth your consideration.
