Will this all be ok together? (i.e. will it fit)
26 Jan 2005
OK building my next pc decide on the components I want to purchase, want to check if they will fit.
The pc is designed as a low spec rig, it will be used for office work/ playing a few games (not important)/ viewing movies.
I am mainly concerned about the case, motherboard and cpu cooler fitting, my second concern is the power supply.
Specs below,
AMD A64 3000+ (Winchester)
XFX 6600GT (PCI-e)
Standard DVD RW
70GB western digital (IDE)
Asus A8N-VM CSM Micro ATX
Geil Value 1GB PC3200(2x512mb)
Zalman CNPS7700-ALCU Ultra-Quiet CPU Cooler
OcUK Value Aspire X-Qpack Cube Case
Thinks thats everything, if anyone can reccommend a cpu cooler which will fit then please suggest it.
Do you think the aspire psu will be ok with this equipment?
Is the cpu cooler I have already in my shopping list ok, plus will it fit?
Many Thanks in advanced :D
Looks like a good spec. The CNPS7700 does fit, check out the Aspire threads in the SFF forum and someone over there managed it.
The mobo is good, but if you fancy overclocking loads then get a Biostar Tforce 6100. If you still need all the extra features of the 430 chipset then I'd go for a Foxconn 6150 board as they overclock pretty well too. If neither of the above, then the Asus will fit the bill nicely.
