Will this be a decent rig?
The GFX card fits.
You may want a K CPU to overclock? Have a look at Antecs range of water coolers as they are at killer low prices.
I was going to say its worth looking at the K range.
The 1TB Barracuda is out of stock but I'd say grab a 2TB as they're only £15 more for double the storage.
The GFX card fits.
Sorry, a K CPU? I'm a bit lost :D. I will have a look at the antes water cooling range. Any recommendations?
I won't actually be building the rig until the end of this month so hopefully they will get some more stock. I have plenty of portable Hard Drives for storage.
K series allow overclocking with the Z97 boards, the cpu you have in your basket does not :p
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £187.99
Total : £197.59 (includes shipping : £8.00).
Thanks. I've been out of the PC game for quite some time, I saw that Devils canyon processor when I was putting the parts together but couldn't work out what the difference was, I thought it was a newer revision of the i5.
+1. Looks nice.
Thanks.
Yes the Devils Canyon is the 'Refresh' CPU. It has improved thermals and a slight speed increase.
YOUR BASKET
1 x BitFenix Spectre PRO 230mm - Black £15.95
Just a suggestion (not a necessity) if you can stretch a bit more. Will help push air across the mobo/direct it to the exhaust/s, to help with temps. Brings a 7v molex which is ideal as it's not noisy like that and still pushes enough air. The 120mm case fan on the front is pretty useless (in terms of both positioning and effectiveness).
