Will this be enough
What is the rest of your system?
COOLERMASTER ELITE 311 BLUE CASE
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3470 (3.2GHz) 6MB Cache
Motherboard ASUS® P8H77-M: M-ATX, DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX™
Memory (RAM) 4GB SAMSUNG DUAL-DDR3 1333MHz (1 X 4GB)
Graphics Card INTEGRATED GRAPHICS ACCELERATOR (GPU)
2nd Graphics Card NONE
Memory - 1st Hard Disk 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
2nd Hard Disk NONE
RAID NONE
1st DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler (£19)
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options 4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDAR
yes, but a bigger one would be better as it will be at max
140Watts [Max Power Draw] for card
none overclocked i5 and system just
i'd still go for at least a 500/600 myself
450w will be ok, on Andantech they get 287w when gaming, but they tend to use a higher end system.
The vast majority of people go overkill on graphics card. As a rule, 500W is enough for a single card setup, 750W for SLI/Crossfire. You'll normally get away with 450/650 for single/multi card, but best to be safe for a few pounds extra.
Calculators are based on the theoretical maximum current draw for all the parts in your PC, but virtually nobody maxes out everything at once. If you look at reviews where they actually measure power draw you can get a better idea of real world use: but you have to bear in mind that they don't use as many hard drives as many real-world users, and that your PSU is one of the few parts in a PC that actually gets worse as the capacitors degrade, so you're best off going for one with more power than you need to be sure. And finally, re-using a PSU is one way people save money on upgrades, so it's nice to have a little extra headroom.
A gaming rig will pull around 300W now in most reviews. Add on a bit for your extra hard drives/peripherals (even charging a phone adds 2.5W) and some overhead for capacitor degradation and a graphics card upgrade and you end up at the 450-500W mark most people recommend as a minimum.
