Will this be ok for me?
17 Jul 2015
I've just had built my first gaming pc but will also be used for general pc stuff including watching videos etc. I've got an overclocked msi gtx 970 in there but can add another at a later date.
This is my favourite so far...
Asus MX27AQ
What's your opinions please guy's. Max budget of £400 and want 27".
I mainly play skyrim, witcher 3, racing games etc.
Thanks.
I'm used to playing a ps4 on a 42" tv.
This is my spec...
Case - Nzxt Phantom Full Tower (white),
CPU - Intel Core i7 4790k,
CPU Cooler - Corsair Hydro H55,
OS Drive - Kingston V300 SSD 120GB,
Data Drive - Seagate 1TB,
Memory - Kingston Hyper X Fury (white) 4GB 1866MHZ x2
Motherboard - Gigabyte Z97X-SLI,
OS - Windows 8.1 but will upgrade to Win 10,
PSU - Corsair CX750 750w,
GPU - Nvidia MSI GTX970 4GB 256bit Armor OC.
Opinions please guys.
Yes, seems like a fairly decent all-around monitor. It will be 60Hz, though. For gaming, 144Hz and variable refresh rate technology (for nVidia GPUs it would have to be G-Sync) monitor would be better, but there might be other compromises to be made.
If you're willing to stretch your budget a bit, then there's also the Asus MG279Q. Although, you'll lose the benefit of Freesync, because you have an nVidia GPU. But, if at some point in the future you purchase an AMD GPU, the Freesync will again be available to you. In any case, it's an 27" 1440p IPS panel with a 144Hz refresh rate. With or without Freesync, this is apparently still the cheapest there is with those features. (It's also flicker-free, btw.)
Here's a review for the MG279Q:
http://www.tftcentral.co.uk/reviews/asus_mg279q.htm
The thing is mate I want good colours etc too. I'm never going amd so freesync is no good for me. I have only ever used 60hz as I'm used to gaming on my ps3/4. Do I really need it?
Do you think 1440p will be ok with my above spec?
144Hz, 1440p and your rig:
Well, you won't really NEED it, but yes, 144Hz truly is good for gaming. What's your requirements for quality? Do you prefer smoothness or extra detail? With your rig, you wouldn't be able to keep Ultra settings at 1440p and still get 100+ fps on the newer games. You'll probably have to drop to High, and in more demanding games maybe even Medium. If you're SLI'ing the GPU later on, then you can put the settings back higher.
For specific games:
http://www.bit-tech.net/hardware/graphics/2014/09/19/nvidia-geforce-gtx-970-review/9
So yes, you should be ok with Skyrim. For racing games, at least Grid 2 seems ok:
http://www.anandtech.com/show/8568/the-geforce-gtx-970-review-feat-evga/12
In any case, if you want to keep IPS with its superior colours as a requirement (and that's what I would also recommend you do), then indeed, the 144Hz will currently go above your budget, as the MG279Q was the cheapest with the required features, and even that was going above budget. But just to make sure: even without being able to use the Freesync, it would still be a very good choice.
But, if you don't want to exceed the budget, then the MX27AQ seems like a fair choice. You might have already found it, but here's a German prad.de review for it:
http://www.prad.de/new/monitore/test/2015/test-asus-mx27aq.html
Thanks for spending the time to do that mate.
I want as high as quality as possible and think I'll prefer extra detail to smoothness but I really need to see both in person to decide.
So it would be a good idea for me to get 1440p to future proof myself :)
So out of the above monitors would I get the same quality being IPS?
Thanks for you're help.
Personally, I don't think there's anything to "future proof". 1080p hasn't even yet reached its prime. Check this post for more info:
http://forums.overclockers.co.uk/showthread.php?p=27137474#post27137474
The important quote from that post:
All in all, I think most people are grossly overestimating the ubiquitousness of 1920x1080; in reality, it hasn't even reached its peak, yet. It's still less than 10% of users. Anybody can think what they want, but 1920x1080 probably ain't disappearing anywhere for at least 10 more years... What we're seeing here in a hobbyist forum is far from what the actual situation is. Here's a quote from one of the sources I used: "1980×1080 exceeded 9% in May 2014 and may become the most popular screen resolution in the next years!" ... Yes, that ubiquitous. My guess is that it will peak in about 6 years, after which it will slowly decline. Also, don't mix up RELEASED new monitors, SOLD monitors and USED monitors.
Furthermore, 1080p is where the human eye-sight is starting to become the limiting factor. In essence, most people's eyes can't tell the difference from any sensible viewing distance(*). But this is an individual matter (especially younger people have better eyes), and the benefit of 1440p depends on your own eye-sight. For comparison, I'm perfectly happy(**) with 1080p on a 42" HDTV, from a 1m distance. Then there are some people complaining that 1080p is too limiting for 24", from whatever distance they are looking at it.
(*): recommended minimum viewing distance is 1x-1.5x the diagonal of the monitor -- move closer than that, and you'll have to start physically moving your head, not just your eyes
(**): happy in the sense of resolution, but Philips has messed up the colors on my set, as well as other features
Forgot to mention, though you probably already noticed:
Yes, AHVA is indeed also an IPS-variant, even though the name implies to VA panels. As for whether the earlier mentioned monitors are equal in quality? Hard to say, as the reviewers might have different quality standards. Then again, from a brief glance neither review found anything to worry about. In essence, they should be fairly close in image quality (they're both 1440p, as well).
I don't agree with this, at anything over about 23-24" 1080p is painfully obvious on a monitor, especially with text and normal use (I don't even have very good eyesight). Gaming at 1080p on my 40" TV is "ok" but 4k looks a lot better. Anything over 98PPI looks good enough for a monitor that you use to read text etc. 1080p 27" is 80ppi which does not look good.
I understand if some people are not content with 1080p. Like I said, it's an individual matter. And if Bone9 feels like 1080p is not enough, then by all means, you should go for the 1440p. Both of the monitors mentioned here are 1440p and 27", so it doesn't make a difference when choosing between those two.
Nevertheless, the "98PPI" and "80PPI" mean nothing if you don't include your viewing distances. Sure, if you look at the monitors from a 10cm distance, even 200PPI will surely appear blocky.
Looking at a 1080p 24" monitor from a 61cm distance is identical to looking at a 1080p 42" monitor (/HDTV) from a 107cm distance. The first one is 92PPI, while the latter is 52PPI.
