Will this be work - i5 Build
They do work together...but thats an awful lot of RAM to be using.
Do you need 32GB? Do you have a copy of Windows that supports that much RAM?
Also for a single GFX card a good 550W PSU is plenty and indeed there are higher quality units than the CX range.
The Kingston V300 range also isnt a very good SSD.
Hows this?
My basket at Overclockers UK:
Total: £776.53
(includes shipping: £12.60)
A case that has more than one fan fitted.
A PSU with Japanese capacitors etc..made by Seasonic.
A board thats cheaper but has higher grade audio.
