I am 90% sure this build will all work together, but can someone just make sure because I don't want to fail
CPU/MOBO/RAM
http://www.overclockers.co.uk/showpr...odid=BU-074-OE
Graphics
http://www.overclockers.co.uk/showpr...odid=GX-114-MS
Case and PSU
http://www.overclockers.co.uk/showpr...odid=CA-233-CM
HDD
http://www.overclockers.co.uk/showpr...odid=HD-247-SE
Also, What kind of speeds will I be able to overclock that graphics card too?
Also, the bundle says it is pre-built, what exactly does that mean? Will I still have to fit the cpu cooler? Which box will it come in? How do I know if some of the parts are straight "out of the box" if it is pre-built?
Thanks
CPU/MOBO/RAM
Graphics
Case and PSU
HDD
Thanks
