Will this car run on Biodiesel
18 Oct 2002
Manchester
Ford Fiesta 51 reg 1.8 TD a mate of mine said that there were 2 types of engine put into these cars one made by Isuzu and the other Fords own .. I dont know if this is correct but how can I find out what type of engine this car has and if it can accept Biodiesel
Don't know about biodiesel, but there is only 1 engine, made by ford.
Electricl fuel pump, direct injection not commonrail...someone like SB118 would know about the biofuel I guess
AFAIK proper biodiesel is fine for virtually all mechanicaly injected systems, it's vegetable oil which causes the problems with some of them
Biodiesel is fine in pretty much any diesel engine.
Vegoil needs a mechanical pump, preferably a Bosch. You can use veg in a Lucas, but only in very weak mixture with pump diesel.
