Fitting a higher spec P4 than the mobo will support. For example a 3.2 Prescott in a Dell mobo that currently has a 1.9ghz 400fsb P4 installed? I only want to check the higher spec CPU works and it is much easier to swop CPUs in my old Dell GX260 then my main rig. Would it damage the CPU or the mobo and will Windows actually start?
All I want to do is check the CPU is working ok before going to the hassle of putting it in my main rig where the HSF is quite fiddly to remove!! Just don't want to blow anything up
You won't get any problems with that one, its good for another 700MHz on stock volts
