There's no room in my HTPC for more HDDs. I've decided a NAS is probably the better route anyway, allowing me to access my media from any room using the fire tv stick for example.
Now some NASs look nice, all enclosed etc but they're expensive and can be noisy so I've been trying to spec my own. All i need to do is have drives show up on the network and they only need to be as fast as needed to stream video. I've read that USB2.0 is quick enough for the highest quality blu-ray material. 4k maybe not but if I can't justify a couple hundred on a NAS then I sure as can't justify a 4k tv yet
So here's my plan:
I use the Raspberry Pi as the controller
Then the hard drives plugged in using this
With the data usb into the pi and the power usb into one of these
Also hack together some sort of case.
The only thing I'm concerned about is powering the HDDs via USB. That particular hub will spit out 5V at 2.4A.
Is this likely to work?
So here's my plan:
