- 22 Mar 2009
- Cornwall
has anyone had any experiences with the NZXT BETA EVO Classic Series case?
my criteria is i need a case that will give good airflow to keep my i7 cool, allow 4 or more hard drives and fit my 9800GTX+, with the possability of upgrading to 2xHD5770 or 2xHD5850.
not sure if im allowed to link to NZXT site so here is the info
cheers.
MODEL : Beta EVO Series
CASE TYPE : Mid Tower Steel
FRONT PANEL MATERIAL : PLASTIC
DIMENSIONS (W x H x D) : 200 X 430 X 501 mm / 7.87" x 16.9" x 19.7"
COOLING SYSTEM
FRONT, 1 X 120mm Blue LED (included)
REAR, 1 X 120mm
SIDE, 2 x 120mm
TOP, 2 X 120/140mm
DRIVE BAYS - 9 DRIVE BAYS
4 EXTERNAL 5.25" DRIVE BAYS
5 INTERNAL 3.5" DRIVE BAYS
Screwless Rail Design
MATERIAL(S) Steel with black finish
EXPANSION SLOTS 7
POWER SUPPLY 500 WATT PS2 ATX 12V 2.0 ( OPTIONAL )
WEIGHT 7.28 KGS (W/O Power)
MOTHERBOARD SUPPORT MOTHERBOARDS: ATX, MICRO-ATX, BABY AT
Features
* Fits ATX Standard Motherboards and Power Supplies
* Fits large 10.5" performance graphic cards
* Expanded cooling directly cools video cards and CPU
* Support for up to 6 120mm fans with the option of dual 140mm at the top
* Screwless installation for hard drives and external 5.25" drives
* Black Internal finish for sleek look
* Meshed front panel allows for better airflow than traditional cases
* Superior wire management with bottom mounted :: PSU and CPU punchout for heatsink removable
* Removable PSU filter
* 180 degree Turned HDD for a cleaner internal finish and better wire management
* External Dual radiator support
* Top mounted USB/Audio for convenient usage
cheers.
and i pasted all the specs they give too
