I've just taken a look at my fans and I'm going to re arrange them a bit to try and reduce the noise a bit and also to put my top vent fan onto a header.
I've got 3 sys fan headers and 1 cpu fan header and I've also found 2 molex to 3 pin adapters, you can stack the 2 together so you can get 2# 3pin adapters.
I was thinking on putting the 2 voltage reg fans that are on my heat sink as well as the back vent fan which is line with them together onto the molex, I assume if I take the red and black ends out of the 3 pin connector block and wire it into the molex yellow and black I should be able to run it?
Then the 2 front fans and the top fans would go into the 3 sys fan headers?
