Will this fit, 360mm Kraken Extreme / Lian Li PC-O11 Dynamic Midi-Tower
10 Jan 2011
Hello,
Pretty much as above, Will the 360mm Kraken Extreme fit in the PC-011, as I understand it not all 360mm rads fit or it's really tight.
I have the Kraken AIO on the CPU, but I'd like to get my gpu under one also.
Many Thanks if anyone can answer it or has done it..
Hello,
I have one of the biggest (length and width ) 360s you can get and just works (alphacool 45mm clad in a metal box) , so AIOs should be fine
You sir are a diamond, btw thats a really clean looking / tidy PC, is the case nice to work in? I'd love mine to look as good as yours.
Hello,
One question. Have you not considered this?
https://www.overclockers.co.uk/ek-w...-cpu-water-cooler-threadripper-hs-00g-ek.html
I know is more expensive, but you would be able to watercool your GPU also.
It provides great value, performance of a full custom watercooling solution and ability to expand in the future.
Just a thought. Saying that because I have the Predator 360 for 2 years now, and has being great asset to my system, having changed numerous CPUs (sockets) & GPUs. And also having replaced the CPU blocks with monoblocks.
