will this fit in a sugo 01
5 May 2004
hi all well am on a bit of a tight budget and cant find a retail x2 4200 anywhere
so gonna get a oem but i aint got much left for a cpu cooler
this one is at ocuk anyone know if it would fit ok
my psu dosent have the bottom fan so there would be no conflict which is better but the width worries me
http://www.overclockers.co.uk/showproduct.php?prodid=HS-025-AR&groupid=701&catid=57&subcat=821
but i have seen some people saying they have the zalaman in theirs and looking at the specs that seems to be a tad wider
http://www.overclockers.co.uk/showproduct.php?prodid=HS-022-ZA&groupid=701&catid=57&subcat=821
The Zalman fits - I know this as I had one in a Sugo SG01, it's now in my Sugo SG03!
Never seen the Arctic Cooling one before though, is it a better cooler than the CNPS8000? And i'm also interested in if it would fit. :) :confused:
if i have to get the zalamn it means going down to a x2 3800 instead of a 4200
and the matx board i have is a msi one wich is great and has everything i could ask for
except multipliers and mem clocking in the bios lol
so can only change the fsb
i am wondering if the width of the artic cooling one though is
108mm plus 60mm on each end for the fan making it a whopping 228mm
