will this fit?
1 Jun 2009
i have read that my new board im going to order today the asus rampage 2 is slightly bigger than standard atx anyone know if a atx case like the storm will fit it? or if not can anyone recommend a case with a window that will? cheers
The gene is matx, the rampage is slightly longer measured perpendicular to the I/O panel. Messes with people who cut holes in motherboard trays.
I don't know the case you have in mind, but I would be astonished if it doesn't fit. Most cases leave clearance beyond the atx spec
i went for a haf in the end least i know it will defo swallow it and i am going to mod it a little keep an eye for me build log as soon as i get my bits 2mar
