will this fit
2 Aug 2006
Liverpool
hi i have the lian li a10b and was wondering if these items would fit in it
1. ati hd 5790
2. asus rampage 3 extreme
3. Prolimatech Megahalems Performance CPU Cooler
sorry if this is in the wrong section if it is can a mod please move it.
thanks
Hi, You will fit the Mobo and cooler no problem, the 5970 may be a little tricky you might want to do some measuring as the 5970 is 12" long it is a huge card so you are going to need plenty of space!
sorry i got the wrong card it should have been the 5870
so the mb and cooler will fit
From Lian Li's website here:
So yeah the 5870 will fit no problem too.
I would imagine that your cooler will fit without any issue, I currently have a Megaharlems in my Lian Li and it has loads of room shouldn't think you would need another cooler
