Will this fit
SilverStone say 167mm CPU clearance. (my R2 spec says 165mm clearance and TC14 fits by slipping fans closer to mobo) Make sure fan will clear RAM. You only have 27mm :D
http://www.overclockers.co.uk/showproduct.php?prodid=MY-017-SA
Twin cooler size comparison
K2 . . = . 140x128x158mm 146x154x160mm w/fans (WxDxH looking from front of case)
D14. . = . 140x130x160mm 140x158x160mm w/fans
TC14PE = 140x134x160mm 140x159x171mm w/fans
SA . . = . 147x123x160mm 151x149x160mm w/Fans
SB-E. . = 155x105x164mm 170x130x170mm w/fans
Extreme . 155x105x164mm 155x130x165mm w/fans Reason it's smaller is 140mm fan vs 150mm fan.
K2, D14 & TC14 are about same except for TC14 140mm fans & 31mm RAM clearance stack up to 171mm
SB-E is widest by 15mm. Even wider with TY-150 fan = 170.
Extreme with TY-143 fans is still 151.5mm
