Will this fit?
that's what I thought my case is massive never thought it wouldn't fit.
Any other cooler you would recommend?
Thermalright True Spirit 120M is L132mm x W57mm (79mm w/fan) x H145mm
Thermalright Macho 120 is L120mm x W102mm (127mm w/fan) x H150mm
There are some nice low profile coolers from prolimatech and silverstone, designed for ITX systems and will fit your case for sure.
Get some better airflow fans.
Static pressure isn't everything to look at.
Check Alpenfohm fans, they dont have leds, but would be much better choice.
Or Akasa apache pwm - I have those and they move a lot of air, being very quiet at the same time.
