Will this gaming spec work?
12 Sep 2003
I'm pretty new to building PCs, what goes with what and such, and I want to make sure its good/will work before I go spending a lot, heh.
Asus GeForce 8800 GTS HTDP 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Intel Core 2 Quad Pro Q6600 "Energy Efficient 95W Edition" 2.40GHz (1066FSB) - Retail
Gigabyte GA_P35_DS3R (Socket 775) PCI-Express DDR2 Motherboard
Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Western Digital Caviar SE16 320GB 3200AAKS SATA-II 16MB Cache - OEM
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Akasa Eclipse 62 Aluminium Case - No PSU
Samsung SH-S203BEBN 20x20 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM
Microsoft Windows Vista Ultimate 64-Bit Edition DVD - OEM - 1Pk (66R-00838)
I'm not sure at all what OS is recommended for a gaming PC, so any help with that would be great. Also, if anyone has any recommendations for replacements, or improvements, it'd be really appreciated. Idealy I'd want to keep my budget under £900, so if there's some hardware which tends to give the same preformance for less price, I'd be happy to hear about it, hehe.
Thanks in advance.
I havent built a computer for about a year but it really isnt that hard. I will just state a few obvious things from looking at your descriptions of the parts. I dont have time to go and look at each one in depth..
With that in mind, I assume that the intel core 2 quad pro is socket 775, so your motherboard and cpu will be compatible. As will your CPU cooler (Tuniq Tower 120 CPU Cooler).
Looking at your motherboard (just the description you have given) and GPU, both state PCI-E compatability so they should be ok, but there might be somthing im missing as I have not made anything with a d3d10 card..
Your psu will do fine, and because your motherboard is pretty 'up to date' you can almost allways expect that it will accept your DVDRW sata drive, so that should also be ok. The same should also be said for windows vista.
I would have to look at your chosen motherboard in more detail to see if it is capable of housing your selected ram and harddrive. But it 'probably' should.
Also, I guess you should use vista for the d3d10 support. Also dont forget you need a case ;x
