You realise that there's only a limited amount you can do to overclock the i5-2400 on a H67 motherboard?
Ah thanks for that and I have noticed that a lot of boards only have 2 mem slots now.
A lot of mATX boards have 2 memory slots due to their small size.
How about something like this:
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £161.99
1 x Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** *LOWEST UK PRICE* £68.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £49.99
Total : £292.36 (includes shipping : £9.50).
Is much better than your original spec, and will allow you to overclock properly. With a non 'K' chip, overclocking is very limited and you probably will not notice a big performance increase.
If you use the PC for gaming you could go for 4GB of RAM because all games still use 32-bit architecture and will for a long time.
+1. I second the motion.
The Mem doesn't get OC, even if you push the CPU to 5GHz. So any decent stick will be good to go. The HyperX is great. XMS3 as well.
what the hell is BCLK, as Im out of the loop of the new tech that boards use nowadays, as it says the i5 dosent like BCLK, so can you disable it?
Im deffo going to be upgrading in a few weeks now, and I might have a buyer for old pc, but he isnt having my gpu or hdds/ssd. Anyway Im getting ichy feet now, so I thought Id put my basket up on here and see what you think. I think I can afford a better cpu cooler, so hows the "Be Quiet"? Also has the motherboard got a good cpu fan profile in the bios thats fully adjustable?
Nice, is Black and Grey the theme you are going for? The bequiet gets good reviews.
I dont know about the fan profile but there maybe a windows based tool that can alter the RPM at varying temps.
A bit like this, you just move the two colour balls to change the profile.
