Will this gpu block fit a ati 4670
20 Nov 2009
hi
i have two ati radeon 4670's in crossfire
and i have just bought a load of w/c bits and it came with only one danger gen
maze 4 gpu block which is blue, i cant seem to find it on there site and would like to get another,
but i also thought about gettin two new ones and i saw this on OCUK which is
in my budget and are full cover ones instead of just the main chip ones.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-013-XS&groupid=595&catid=667&subcat=
I was wondering if this would fit?
can anyone help?
I doubt it, you need to buy a block for your exact card, as I doubt the 3870's have the same PCB layout as a 4670.
i cant seem to find any made exactly for it?
would i be able to mix and match blocks so if i used the danger den one for one and a different one eg EK on the other?
Can't see why not.
The Swiftech MCW60 will fit most cards, you should check see if anyone is using that block on the 4670.
