Will this monitor arm 'SilverStone ARM11BC' support Iiyama UW display?
Whilst it's VESA 100x100 for mounting, the page states a weight (without box) of 10.9 KG for the monitor and the arm says a maximum of only 10 KG. I don't know what that specifically refers to, but if the screen itself is under the 10 KG then you will be fine.
If not, any arm that has that mounting size as well as capable of supporting the screen weight will be fine. :)
Hi @Ryan-3 Thanks. I think the 10.9KG also includes the stand, so if we take this off, I am thinking I am close (but under) the 10Kg limit of the ARM11BC. I just wanted to check that weight and VESA mount aside I am not missing anything else?
Nothing else I can think of! I think that probably will be the case so I'd assume you'd be okay.
As long as it fits and isn't overweight, you're set.
