Will this psu be ok ?
23 Aug 2007
Hay all.
I go given a psu off my m8 and i wanted it for my old setup but i am not sure if its upto the job.
what is says on the psu is this
KM Korea P4 model GP-300ATX 12v P4 [300W]
Ac input ( 100-120vac 6.3A 50/60Hz)
( 200-240vac 4.0A 50/60Hz)
DC
Output [+3.3V][+5v][+12V][-5v][-12v][+5vSB]
------- [20A] [30A] [13A] [0.3A][0.5A][2.0A]
-------- +5v,+3.3v 150W MAX,+5v +3.3v+12v 288W MAX
Will need to run
CPU Intel Pentium 4 2.8 GHz (Hyperthreading)
Motherboard MSI MS-6743 ver 1.0
Memory 512 MB DDR RAM - PC2100
Hard Drive 80GB Maxtor 6Y80L0
CD Drive 16 x DVD-ROM
52x24x52 CD-RW
Video Card BFG 7800 GS OC 256mb AGP
What u guys think ?
Cheers for any help :D
That's a very weak PSU. 13A on the 12V rail is poor, and not really up to the task of powering a relatively power-hungry system with a Geforce 7800.
You might find that it works for a while, but I'd seriously consider getting yourself a quality unit. An Antec 380W should do the job nicely.:)
Thanks p4radox
I got another one 15A on the 12v i used that instead and it seems to be working ok so far i played a few games and nothing bad gone wrong lol
I will change it later but if it goes bang in the mean time then thats the risk i have to take lol :D
cheers
