Will this PSU do as a 'stop gap'?
Caporegime
29 Jul 2011
In acme's chair.
I'm pretty sure it will be fine, but may as well get your opinions.
It would be fine to power this system:
i5 2500K @ 4.6GHz w' 1.37v
GTX660 OC
5 fans
2 HDD's
Misc stuff like an SSD, sound card & lighting
With a 600W FSP 80+ wouldn't it?
It's an OEM grey-box, nice and weighty, good amount of connectors, 504W and a total of 72A accross the 4 12v rails.
It was originally pulled from a competitor branded pre-built machine.
It would probably be for a month maximum. The GPU will spend a-lot of it's time at 100% load while folding, and I will probably do some gaming and such as well.
Here's a link to the product page. It looks fairly decent to be honest. http://www.fspgroupusa.com/fsp60080epn85/p/852.html I believe it is actually more efficient than my OCZ ModXstream Pro 700W, and it actually only has 30W less on the +12v :D
Cheers :)
The FSP:
Model = FSP600-80EPN(85)
Max. Power = 600W
OEM = FSP
+12v rails = 4
Amperage per rail = 18A
+12v Max. Load = 504W
Efficiency = 80+ Bronze
My OCZ:
Model = OCZ700MXSP
Max. Power = 700W
OEM = Sirtec
+12v rails = 2
Amperage per rail = 25A
+12v Max. Load = 552W
Efficiency = 80+
Looks alright. Not so sure about the quad rails though.
Not very good. It should work, but I'd try to get a replacement ASAP.
Already have a replacement but I want to leave it boxed up until I do my full re-build & build log. (have a new PSU, motherboard, SSD, and parts for a custom loop, so i'm selling my old stuff off) :)
Nearer 300w, but it will still handle it,
My stock gtx 660 + 2500k drew a max of 150w from the wall during 'normal usage' but this was on a platinum psu. This would equal approx 135w actual load.
2500k @ stock uses around 65w fully loaded
and around 100w oc'd to 5ghz
I tested the coretemp power reading by comparing the difference with my power meter and its pretty much spot on. This is why I said 200w :-)
FSP PSUs are decent enough. My first branded PSU was an FSP and to my knowledge lasted at least 10 years.
The tend to make budget/mid range branded PSUs for Zalman, Antec, OCZ, Silverstone and others.
Don't worry guys, I found another solution which is just to use my other PC for a while :p
Hence the sig change lol.
