Will this PSU work?
13 Sep 2006
Need your help guys.
Have an unused Antec Sonata case, with a TruePower 380W supply. (not ATX v.2.0, as far as I know) It has a 20 pin main power connector, 6 pin auxiliary power connector and 4 pin +12v Power Connector. Also sundry molex connectors. .
Will this power a core2duo m/b such as the Asrock Conroe Crossfire.
(I know I'll need molex to sata converters)
Grateful for help
Are you intending to Crossfire with that PSU? If so I'd forget it right now, otherwise yes that should cope although you will also need a 20-24pin adapter for the motherboard and I probably wouldn't try overclocking it much(at all).
