will this ram work? g.skill with asrock
12 Jun 2011
my m/b is ASROCK p67 fatal1ty professional
currently have 16gb (4x4gb of G.skill Ripjaws F3-12800CL9D-8GBXL)
however i really want to update to 32gb..
i was looking at GSkill 32GB 4x8GB Quad Channel Kit Ripjaws X Red RAM DDR3 1866 F3-1866C10Q-32GXL
anyone tried this in the asrock will it work? its not mentioned on asrocks supported ram list but i think its a but out of date (not many single 8gb chips mentioned)
like some feedback before spending £250 on something may not work
thanks
Grant
thanks
Grant
I can't specifically answer your question, but why not go for it as you can always return if they don't work under DSR I would have thought. Or maybe e mail asrock and ask them if they are likely to work ok.
I emailed asrock no reply.. gskill replied saying yes. but they put F4-1866C10Q-32GBXL when my query was about F3-1866C10Q-32GXL . so I have replied to confirm.
also the ebay seller said the ram is in a non re-sealable box so cant be repackaged for return
