Hello,
I'm thinking of upgrading my dual 512MB DDR2 RAM to 2x 1GB RAM.
My friend has told me though, that not all RAM works with certain motherboards etc which I understand to a certain extent.
My current RAM is: x2
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (7F7F7FA700000000)
Size 512 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number CL5-5-5DDR2-667
I'm using a 3.4GHZ P4 with a 8400GS gfx card. Now, I'm looking to buy this:
Kingston Valueram Computer Memory 1GB PC5300 DDR2 667MHz 240 Pin Dimm
Mine says, 'PC2 5300' whereas the RAM I want to buy say 'PC5 5300'. Would the Kingston RAM work if I ordered it?
Thanks in advance
Memory type DDR2
Size 512 MBytes
Thanks in advance
