Will this rig work?
31 Aug 2011
Hello overclockers community, i have bought a lot of stuff from overclockers in the past but this is the first time im buying all components for a new pc and i was wondering if all these would work.
Intel Core i7-2600
Asrock Fatal1ty Intel P67
Corsair Vengeance Blue 16GB (4x4GB) DDR3 1600MHz Dual/Quad Channel Kit
Corsair Hydro H60
Corsair Enthusiast Series TX 750W
ASUS DIRECTCUII GTX580
Thanks in advance
Hi,
All those part will work together.
But if i may :)
You have got a non K chip on a P67 motherboard. In short you won't be able to overclock it. If this was your aim then I'd recommend saving some ££ and getting a H67 motherboard.
If you do want to overclock, look at either the i5-2500K or the i7-2600K, depending on your needs.
i5 for gaming
i7 for heavy video/image editing/3D modeling
By the looks of things you'll be going with the i7, unless you just really like RAM?
If its red and black the theme you are going for then have a look @ this motherboard:
Asrock Fatal1ty Z68 Pro Gen 3 intel Z68 (Socket 1155) DDR3 Motherboard
More expensive than your choice but it will handle the next gen of graphics cards if needed down the line.
Thanks a lot. I budgeted for £300 on motherboard for this build and that one looks great.
I have a acer g24 x2 and the only reason i rabbed a GTX580 was because i want something that will last me for a good couple years.
Thanks
