will this SD card work on my laptop ?
11 Feb 2004
TheWirral
my laptop was bought 12 months ago:
Dell Inspirion 6400
built in memory card reader:
Secure Digital host controllers
SDA Standard Compliant SD Host Controller Vendor
This is the card i want to purchase:
Specifications
Please Note: Please check the device you are buying this card for is SDHC compatible. SDHC cards are not backwards compatible with standard SD Host devices, however standard SD cards are forward compatible with SDHC host devices
Speed performance rating: Class 2 (based on SD 2.00 Specification)
Cards include security feature for protection of copyrighted data
SDHC cards (4GB and 8GB) supports SDHC compatible host devices
SD cards are fully compatible with all SD-compliant devices
Optimal performance for your digital device
High quality and reliability backed by a 5-year limited warranty
Description
The SD and SDHC memory card is a highly secure stamp-sized flash memory card, which can be used in a variety of digital products: digital music players, cellular phones, handheld PCs, digital cameras, digital video camcorders, smart phones, car navigation systems and electronic books, that follows the SD 2.00 specifications.
What is SDHC?
To support the higher capacity needs, SD cards are now requiring a different design. The new SD 2.0 specifications - which supports 4GB and up - is called Secure Digital High Capacity (SDHC). The SD Association has created and defined 3 speed classes to help you identify speed and performance capabilities/minimum requirements of SDHC cards and their SDHC host products.
HMMmmmmm why do i get the feeling It's not compatable with my very old "12 month old laptop" lol
I would contact dell customer support and look at the card reader manufactures website, I would say it most likely will work.
