Will this set up work together?
Is your ram quad channel and do you have a cooler, as the 3930k does not come with one.
on the above post for anyone looking the mobo doesnt support the GPU, i found out the hard way.
Just because you are having a problem getting a display atm, it is incorrect to say the mobo does not support the Gpu. A quick search on the net proves otherwise.
