Will this upgrade be OK?
11 Nov 2009
Edinburgh
I have a Gigabyte B450 AORUS M and have updated the BIOS to F41 does that mean it is OK to drop in a Ryzen 7 3700X?
Cheers all.
Cheers all.
https://www.gigabyte.com/Motherboard/B450-AORUS-M-rev-10/support#support-dl-bios
why not just update to F51
  1. Update AMD AGESA ComboV1 1.0.0.6 for 3rd Gen AMD Ryzen XT series processors
  2. Fix AMD security vulnerabilities for SMM Callout Privilege Escalation
if it supports XT will support anything lower
also make sure REV is correct this ones for REV 1.0 check the manual to see where it says REV on board
