Will this work fine?
If you want to overclock the cpu I would grab a better CPU cooler. I use a Dark Rock Pro 2 for my 4670k system. Using the same board it runs 4.6Ghz and remains cool and quite.
It would be better to get just one set of RAM for now. I doubt you will use near the full 8gb in gaming for a very long time. It is easier to get two sticks of RAM stable when overclock than four. The RAM is also a little tall, which will restrict you in choosing your coolers. What you save in RAM i would throw towards getting a higher quality motherboard like the Gigabyte OC or if you want to keep the red and black theme, the gigabyte Z87X-UD4H
+1 for the Dark Rock Pro 2
Just make sure that your case is wide enough to fit and get low profile RAM.
Change the PSU to an antec or seasonic, will you be going xfire in the future? If not you can drop to 500-600w.
This
YOUR BASKET
SLI:
1 x Seasonic G series 750w '80 Plus Gold' Modular Power Supply £119.99
1 x Seasonic M12II 750W '80 Plus Bronze' Modular Power Supply £99.98
1 x Antec High Current Gamer 750W Modular '80 Plus Bronze' Power Supply (0-761345-06223-7) £99.95
Single GPU:
1 x Seasonic G series 550w '80 Plus Gold' Modular Power Supply £79.99
1 x Antec Neo Eco C 520w Modular '80 Plus Bronze' Power Supply £61.99
1 x Antec High Current Gamer 520W '80 Plus Bronze' Power Supply £59.99
1 x Seasonic S12II 520W '80 Plus Bronze' Power Supply £59.99
...get low profile RAM.
And this
Haswell can benefit from faster memory.
YOUR BASKET
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £65.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLAD38G1600HC9DC01) £56.99
If you want to run with an orange theme have you considered the Gigabyte Z87X-OC, little bit more but it looks wicked? ;)
