Will this work?
16 Feb 2009
Aylesbury
Hi, first post, first build.
I just wanted to know if these components will work together.
Thank in advance for any replies.
Also, is this a good mobo/CPU combo? £220 is really my budget for RAM, CPU, PSU and mobo, and i havnt got a GFX card, so i need onboard graphics for now, but a PCIe slot to upgrade later.
Is this good RAM? I have heard good things about OCZ.
Will there be enough power from the PSU?
Any other thoughts?
I have a case, HDD, OS and optical drive from an old PC so i won't be needing any of those.
Thanks again,
Alex
How about this.?
£5 extra, but you double your ram, get a better power supply, and cpu :p
Product Name Qty Price Line Total
AMD Athlon 64 X2 Dual Core 6000 3.10GHz (Socket AM2) - Retail £68.99
(£59.99) £68.99
(£59.99)
Seasonic Silverpower 500W Power Supply £57.49
(£49.99) £57.49
(£49.99)
Gigabyte GA-MA74GM-S2 (Socket AM2) PCI-Express DDR2 Motherboard £49.44
(£42.99) £49.44
(£42.99)
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) £39.09
(£33.99) £39.09
(£33.99) Sub Total : £186.96 Shipping cost assumes delivery to UK Mainland with:
DHL @ Home Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.99 VAT is being charged at 15% VAT : £29.39 Total : £225.34
well here is another option for you mate lol, the SLIGHT decrease in cpu frequency will be more than comprimised with the build in L3 Cache the Black Edition cpu gives you, and bang of £2 under :D
(£49.99) £57.49
(£49.99)
AMD Athlon 64 X2 Dual Core 7750+ Black Edition 2.70GHz (Socket AM2+) - Retail £57.49
(£49.99) £57.49
(£49.99)
Gigabyte GA-MA74GM-S2H AMD 740G (AM2) PCI-Express DDR2 Motherboard £54.04
(£46.99) £54.04
(£46.99)
(£33.99) £39.09
(£33.99) Sub Total : £180.96 Shipping cost assumes delivery to UK Mainland with:
(This can be changed during checkout) Shipping : £8.99 VAT is being charged at 15% VAT : £28.49 Total : £218.
Does that mobo support phenom processors? The 7750+ isnt an Athlon, it's a Phenom with 2 cores. I'll just check.
EDIT: It does!! :) Thank a lot mate. The same price as my first build with the same CPU, more power, similar mobo and double the RAM.
