Looking at setting up a small training suite, will be set up as a peer to peer network as theres no long term storage or anything needed, as most of the training is web based.
The plan is 10 pc's wired and 8 macs wireless but will hardly be used at the same time looking at 10 concurrent users at one time max. And 2 networded printers.
So far we have a 100 MB connection comming in.
So if we get a 24 port switch connect this to the incoming connection and then connect the ports to the patch cables, this will work for the PC's?
If we then connect 2 Apple Airport Extreme Base stations to the floor boxes which are connected to the switch, would this provide connection for the Macs?
If the printers are connected into the switch to we could then print over ip?
Does this sound right or am i missing something obvious?
TIA
TIA
