Will this work.
3 Jul 2011
I Purchased a Xonar Dg Soundcard (http://www.asus.com/Multimedia/Audio_Cards/Xonar_DG/)
Currently I'm running 2 Gtx 570 in SLI on a p67 Sabertooth thus bot the slots that are the correct size are in use.
One of the smaller slots is free but the card won't fit in as it's full size.
if i buy a converter for the smaller slot to larger one will the soundcard work?
Sorry for my vagueness but i'm not 100% familiar with the terms for the different expansion slots
Thanks
So you cant squeeze it in the very bottom slot?
My be easier to sell the card and buy a PCI-E version.
Afraid not, I have Twin Frozr cards so the cooler the card leaves virtually no space in between itself and the PSU
looking around the internet it will only be slightly more expensive to buy a new soundcard for PCIe than it will be to get a converter
*edit*
it will probably work out cheaper if you sell your PCI card on
