Will this work
8 Jan 2008
Eastham/Wirral
Hi Guys
Having not built a Pc since C2Q6600 would you mind taking a butchers at this little lot and tell me if it will be fine ... not decided which case to go for yet .. low power and silence is appealing .. its just going to be used for general office use.
It won`t be getting clocked thanks
[/IMG]
No glaring problems from this end.
Looks good.
Case wise, i think the Lian Li is the smaller of the two and for your uses probably better.And you don't have to wait for it to be released. :)
It'll work, but you can't really overclock that much on that motherboard. So no point with a K CPU. And the space is limited for a CPU cooler in the Q11.
The Prodigy is a bigger case, but it also means you can add a graphics card to it, as well as a big CPU cooler.
Q11 for HTPC / office, with locked CPU and H77, Bitfenix for gaming and performance with Z77 and 3570K.
Looks good.
Am undecided which case to go for can`t see me waiting for the Bitfenix tbh
As it's being used for office (general use), i don't see a GPU being added anytime soon.
The K version comes with HD 4000 graphics where the non k (3550) comes with HD 2500. The 3570k will keep its value more, in the long run too.
Maybe am going over doing it with the CPU&Board it was the high grafix on the chip that I liked and well` just be upto date really
Yes it will work, but with the H67 board you be able to overclock the cpu.
Thanks .. Sorry I should have said .. As much as i would like to have a play with this new chip, its not going to be overclocked .. Its for my brother
