- 18 May 2010
- London
As title states, will I get any framerate increase by upgrading to a 2500k or greater, but keeping my 5870?
What resolution are you gaming at?
1920x1200
you wont notice any diff upgrading the cpu because your 5870 is being maxed out with the QX9650.
So by upgrading the cpu, your just bottlenecking it, as the gpu cant run any faster, as its running at full tilt with your current cpu.
I went from a Q6600 @ 3.5 to this i5 750. Quite a major performance change in BF3.
Probably best to upgrade the GFX... QX9650 is still a pretty beafy CPU with all that extra cache.
Stick a 6970 2gb in there atleast or a 7950 when it arrives and you will see a large difference.
Ultra textures require 2gb VRAM.
My 580GTX handles Ultra textures perfectly well with a min of 42fps and an average of 55fps so you definately do not need 2gig of video memory for ultra textures (CPU = 2500K @ 4.2)
Remember when DICE claimed you need 2xGTX580's to run the game at its best. Not true it turned out lol
Upgrade the cpu as you will have more and better ram plus much faster cpu which can overclock higher with a mother board which will support Sata3 to get the most out off your M4
