will upping PCIE voltage help the GPU?
27 Apr 2010
ok first of all, abit of background... im running Furmark, and i am noticing that there are these 1-second long pauses which happen randomly... it does not seem to be related to the GPU's overclocking since it doesnt happen less/more often with slower/faster GPU and memory clocks
so i was thinking that maybe the problem lies somewhere else, will i get better stability on the gpu if i up the PCI express voltage? like the IOH and ICH PCI express voltage settings in my bios...
radeon 5870 eyefinity6
core i7 930 3.37ghz
i dont think that the cpu is too slow for furmark, its hardly even using any cpu time when furmark is running
Do you have any other PCI-E cards? A non-standard PCI-E voltage will cause problems with things like sound cards (crackling etc) and may damage others.
