Hi all,
I am having yet more problems with my pc.
I am getting frame rate drops when moving the Corsair mouse around. This isn't just in games but on the desktop and for example YouTube video.
I have clean installed the latest graphics driver and reinstalled the mouse and keyboard software and drivers.
I have tried different usb ports for both the devices.
If I turn the polling rate down to 125 from 1000 it seems better however I would like the polling rate to be higher to match my faster monitor setup (144hz 4ms)
If I use the Logitech mouse I don't get the problem, I think it is a 125hz polling rate.
Things that I think have changed are the bios which was updated because of the graphics problems I was having. I did a clean installed of Windows not that long ago. I had to reinstall the thunderbolt firmware recently, I am not sure if this coincides with the mouse problem. Also I got the creators updated recently too.
In device manager I seem to have something strange with an audio driver that keeps coming back but is disabled.
Things I think I am going to try next are removed killer network stuff. Remove audio stuff. Check windows mouse precision thing.
Has anyone come across this problem?
Is there anything else worth checking?
Should I just clean install Windows?
I am getting pretty fed up with the constant problems with my pc now, I just want to play some games without lag and frame rate problems.
And help is appreciated thanks.
System spec,
Cpu: i7 6700k @4.6
Mobo: Gigabyte z170x gaming g1
Gpu: 2x R9 290x
Ram: 16gb gskill trident z 3200
Keyboard: Corsair k70 rgb
Mouse: Corsair m65 rgb and Logitech mx510
Cooling: custom loop
System spec,
Cpu: i7 6700k @4.6
Gpu: 2x R9 290x
