Odd problem.
When I select a file or folder, F2 or right-click -> rename does nothing.
Rename button on ribbon doesn't work either.
However if I right-click -> properties I can rename the file or folder
This is only happening in Windows Explorer. If I use Q-Dir, rename by F2 or via the drop down meny works normally.
I have full admin rights and ownership of files/folders.
F2 key does work - tried a few ctrl, shift & alt combos in other applications, so it's not a hardware problem.
Any clues on what causing this and how to fix it?
