Win 10 Still On Build 10240 : Help!
15 Aug 2011
Can someone tell me what the latest build is please. I know there was a large update in Nov/Dec, I havent had anything at all.
Can anyone point me in the direction of the update to download, as it never appears in my updates.
Thanks
Mine is the same build number, the updates now download and install in the background most of the time without you knowing.
i had the same problem being stuck on that old build since i upgraded last august! i went online to microsoft and they took control of my pc. they found that for some unknown reason i still had the option to rollback to w7, even though it had been months since my upgrade. this was stopping it getting and installing the latest builds (wouldnt even find them!). the microsoft tech ran the latest w10 installer over the top of my current install and now everything seems fine (for now) and i dont have the rollback option any longer.
I'm on build 10586.104 and have upgraded from windows 7 pro to 10 pro
Same here.
Also for those who aren't sure how to check, the easiest way is just to type "winver" into the start menu/run and click the result. :)
