davestar_delux said:
=walls= I ran that thing and it didn't seem to find or fix anything . I WAS the only account on this machine and Administrator. However, I just enabled the Guest account and it gets a desktop no problem when I log on as that...
Yeah - unfortunately it doesn't tell you if it does fix anything...
As Marc2003 says - it's a corrupt profile. Pain in the a$$ to fix, as you're going to lose most of your settings (desktop pic, etc).
Create a new admin account and log in with that, then go to documents and settings and
rename your old profile (e.g. to <username>.old).
Log out and in with your own account again and you'll have a default profile (i.e. blank profile). Go back to documents and settings and copy over: Application Data, Desktop, Favorites and My Documents.
Unfortunately you'll have to set your background pic, etc again.
Also, if you want to remove standard icons from your win2k desktop - you might want to have a look at gpedit, which is part of the OS and very unlikely to fsck up, unlike TweakUI. (you might even want to look into gpedit before rebuilding the profile - you might be able to rescue it from there...
