26 Jan 2013 at 11:48 #1 Ken Ken Associate Joined 28 Apr 2004 Posts 1,067 Hi, Can I just check Win 7 64 bit is compatible with a Core 2 Duo E6750 and Abit IP35? Also if for whatever reason I needed to switch to the 32 bit version having bought the 64 bit version can I use my product key on a 32 bit ISO? Thanks
26 Jan 2013 at 12:10 #2 DJDaz DJDaz Associate Joined 9 Nov 2004 Posts 1,177 Location Essex Definitely works with a Abit IP35. Can't comment on the E6750 though as i don't own one.
26 Jan 2013 at 12:16 #3 kirbz kirbz Associate Joined 2 Mar 2006 Posts 641 Location Derby http://ark.intel.com/products/30784/Intel-Core2-Duo-Processor-E6750-4M-Cache-2_66-GHz-1333-MHz-FSB The CPU is 64 bit so should work.
26 Jan 2013 at 12:39 #4 The Dirts The Dirts Associate Joined 13 Jun 2005 Posts 127 Location Cider Country Win7 64bit been working fine here for a couple of years. Specs in sig, similar to what you have.
26 Jan 2013 at 15:53 #5 Ken Ken Associate OP Joined 28 Apr 2004 Posts 1,067 Thanks guys Anyone know the answer to my Windows key question?
26 Jan 2013 at 15:55 #6 d_brennen d_brennen Soldato Joined 30 Jan 2009 Posts 17,555 Location Aquilonem Londinensi 32/64 does not matter, the product key is valid for either
