Win 7 can't change default sound device
28 May 2007
Hi,
As the title says for some reason I'm unable to change the default sound device when it had been working fine. I am using a 5.1 speaker setup and a usb powered corsair headset. If I try and 'set as default' the headphones in 'Sound' nothing changes, I also can not enable or disable any devices listed. I've been able to do this for the past 4 months or so since installing Win 7 and I can't think of anything I've changed.
The strange thing is, if I use the options to change the device used within a game for example, the sound does switch between them so they are both working currectly.
I'm really scratching my head over this, anyone got any ideas?
Cheers
