Should I be changing display settings in CCC or Win 7? It seems the 2 aren’t very compatible. As in, I’ll change the Win 7 display settings and the incorrect ones show in CCC and when I change the ones in CCC, it doesn’t ouput correctly.
For example, I set it to the highest res (1080, which my TV + monitor support) in Win 7, then messing around with CCC I clicked rotate screen and not only did it rotate my screen, it changed my resolution to a much lesser one.
It seems a bit of a pain in the backside to be honest.
I am thinking of removing CCC and not bothering with it as I don’t see what benefits it has apart from adding bloated software on system start up.
What do most people do with this setup? Is it possible/recommended to install just the proper drivers for my Radeon and use Win 7 to control all aspects of output?
Cheers.
Cheers.
