So, I came back to my PC the other night after popping into the kitchen and it had thoroughly locked up. Mouse was moving, but absolutely nothing was responding. So I did what anyone else would do in that situation, and powered down. Gave it a few minutes, then booted it up again.
Now, when it boots up, it loads windows and gives me a choice: Load Win7 normally, or start windows system repair.
Loading win7 normally, it shows the glowing windows icon as it loads, then the screen goes black, and it reboots, taking me to the same choice.
Selecting the windows system repair tool however, loads up a nice pretty blue wallpaper, and gives me a perpetually spinning circle for a cursor - ie, doesn't do a great deal in the long run.
So, I whacked out my Win7 install CD hoping to fix whatever was up there. Boot off that, and it hangs on 'Loading Windows Setup'. So no joy there.
Also thought I'd give Memtest86 a bash, see if there's anything up. Had no errors whatsoever. Following that, I thought I'd try Dell's own built in diagnostic tool. No errors there either.
Currently, I'm on an ubuntu live DVD - all my files are intact, hard drives are working and I can access everything.
It's a Dell XPS 430 with:
Intel Q8300
4GB RAM
ATI HD4800
Boot HDD is something from Dell, 1TB, with three partitions:
-OS, 984GB NTFS
-DellUtility, 82MB FAT
-Recovery, 16GB NTFS
WD Caviar 250GB HDD for media.
I've already found some advice about disconnecting non-essential peripherals such as FDD and front USB ports/card reader etc. But that's not done a great deal.
Also, being on an ubuntu live DVD, and being able to access the files on my boot disk, is there anywhere I should look, anything I can do to diagnose or even fix my problem from within ubuntu?
Basically, if anyone has any ideas, I'm all ears!
Cheers
Update: I've also run a bucketload of tests from Ultimate Boot CD - nothing seems to be wrong, again.
Intel Q8300
4GB RAM
ATI HD4800
-OS, 984GB NTFS
Cheers
