I did a install on my 1tb WD black thinking i could shrink the drive afterwards.
Seems i cant do this with my c drive because of immovable files ! Partition magic 8 says its not compatable, so im stuck
Think you're very luck that Partition Magic 8 didn't screw your current install, used it when I had Vista and that trashed 3 of my disks after saying there was a fault and I should let it do a repair.
when resizing a Win7 boot partition with parted magic 4.5/gparted, the resulting system becomes unbootable or has to be repaired with Win7 full version.
I know this bug is really a problem with gparted not setting some Win7 flags properly, but maybe the code for this would be better suited inside some NTFS tools that knows how to fix broken NTFS boot partitions. Perhaps you can include this in Parted Magic 4.6?
