hello all, having massive problems with my windows x64 installation.
I've had win 7 32 bit running fine in my machine but I've decided to upgrade the memory so I had to install 64 bit.
I'm using a bootable USB version of the installer as my cd drive is a bit knackered. The installer boots fine and runs through no problem but on the final reboot when it says starting windows the machine just parps out and reboots again into a loop.
I'm installing on a coz vertex 2e drive which as I said has worked fine with my previous win 7 installation - its worth noting that none of the hardware has changed in the Machine at all the new ram hasn't turned up i m still on the original 4gb. The HDD is set to achi mode but I've also tried it with achi turned off.
I've done a fair amount of googling and most places say jts to do with achi or a possible PSU issue but I can't see how that is as all my hardware is the same as before and the machine worked flawlessly!
I've even done a win 7 startup with the auto reboot disabled incase it was throwing up a bsod but even then it just reboots!
can anyone help as I'm pulling my hair out hah! Sorry for the lack of formatting and general untidyness of my post - I'm posted from a tablet.
my pc spec is.....
q6600
gigabytes ep43-s3l
2x2gb corsair xms ddr2 pc6400
GeForce 7800gt
ocz 60gb vertex 2e
anyway any help is appreciated!
my pc spec is.....
q6600
gigabytes ep43-s3l
GeForce 7800gt
ocz 60gb vertex 2e
